Problem with crunchyroll plugin?
Posted by Tri
Tri
September 02, 2014 07:04AM
I have the newest 1.0.3 and 1.0.2 version of the plugins and I don't know if only I have this problem but as soon as I start downloading it says "download complete" and it leaves me with 0kb flv file on certain episodes not on all.It does that on both plugins.I am using VPN since I am not from US.Any help? Here's the log:
Tue Sep 02 08:56:31 CEST 2014 WARNING: Couldn't create fir C:\Users\User\AppData\Roaming\VitySoft\FRD
Tue Sep 02 08:57:09 CEST 2014 WARNING: Icon image for plugin 'crunchyroll.com_premium' was not found
Tue Sep 02 08:57:31 CEST 2014 WARNING: Couldn't create fir C:\Users\User\AppData\Roaming\VitySoft\FRD
Tue Sep 02 08:57:35 CEST 2014 WARNING: Server sent error: [method: _error, sequenceId: 1, streamId: 0, args: [null, [[STRING(0x02) level: error], [STRING(0x02) code: NetConnection.Connect.Rejected], [STRING(0x02) description: Connection failed.], [STRING(0x02) description: [ Server.Reject ] : Connection failed.]]]]
Tue Sep 02 08:57:35 CEST 2014 WARNING: video duration is null
and an example of episode I want to download:
[www.crunchyroll.com]
Re: Problem with crunchyroll plugin?
September 03, 2014 09:56PM
Hmm.. rtmpdump also failed to download the video.
Maybe ntoskrnl can take a look at this, if he has time.
September 04, 2014 04:33PM
The video seems to be georestricted. Worked fine for me with US socks proxy.
Tri
September 05, 2014 06:48AM
Could you please tell me how to use socks proxy with frd? I used VPN only until now.
Edited 2 time(s). Last edit at 09/05/2014 06:49AM by Tri.
September 05, 2014 07:12AM
First you need to find a suitable proxy. I don't know how the VPN works. Perhaps it would work for this too. Could you describe how you use it?
I actually used Tor for this. Then I simply went to Options > Preferences > Connections > Configure proxy, and filled in the details.
Tri
September 05, 2014 09:10AM
I am using Softether VPN client manager.There i just look the list of US servers and connect to one of them like shown here(step 2):
[www.vpngate.net]
The video streams fine for me also in browser but when I want to download it,it shows the error i mentioned earlier.
Edited 3 time(s). Last edit at 09/05/2014 09:12AM by Tri.
September 05, 2014 11:37AM
Okay, I tried using that VPN, and indeed I get the same error.
Using the VPN I get a stream from "fplive.net", but using Tor I get a stream from "edgefcs.net". It seems that these "fplive.net" streams do not work.
I tried to investigate this using Wireshark, but it only shows the encrypted VPN traffic.
Tri
September 05, 2014 04:00PM
> same error.
> work.
Could you make a more specific tutorial on how do you use frd in combination with tor,please?
Edited 2 time(s). Last edit at 09/05/2014 04:01PM by Tri.
