uloz.to plugin problem
Posted by kahless
October 16, 2014 09:42AM
FRD 0.9u4 build#635
uloz.to 1.1.5
When I try to download anything from uloz.to, I get the following error: ERROR - Access denied (CHYBA - Byl odepřen přístup)
Just any files, for example [uloz.to]
Hello, I've got a problem with uloz.to plugin. I'll be very grateful for any help with the issue.
Thanks very much
kahless
Edited 1 time(s). Last edit at 10/16/2014 02:53PM by kahless.
Re: uloz.to plugin problem
October 17, 2014 09:50PM
The sample link works fine for me.
Please attach app.log. To locate app.log: Help -> Browse to log file.
October 31, 2014 09:51PM
Thank you for the reply, pelase find the log.
open | download - app.log (2.4 KB)
November 03, 2014 10:07PM
From this page, specifically at :
FRD can't update plugins - Access denied on Windows Vista/7 if FRD's directory is placed in Program Files...
Workaround:
Run FRD as administrator
Solution:
Upgrade to version 0.83 rc (or higher) and either move FRD to another directory or run FRD as administrator (right click->Properties->Run as administrator).
November 03, 2014 11:26PM
No, this seems to be something else as he's running the latest version (see the "couldn't create fir" smiling smiley).
Make sure the destination path is valid and writable and that the disk is not full. Also make sure the %TEMP% folder is writable and the disk is not full.
Edited 1 time(s). Last edit at 11/03/2014 11:27PM by ntoskrnl.
November 04, 2014 03:32PM
Thanks a milion! The Run as administrator worked. I've tried many other things but I've completely forgotten about this simple one. Once again, thanks
Edited 1 time(s). Last edit at 11/04/2014 03:33PM by kahless.
November 04, 2014 05:48PM
Running as administrator is not a solution, it's an ugly workaround for something else that's wrong.
November 04, 2014 08:08PM
ERROR - java.io.IOException: Přístup byl odepřen (Access Denied)
ensure you have Windows permissions set to allow non-admin users to write to the destination path
... Disk full has its own error message
