ZIPPYSHARE.COM DON'T WORK PLEASE HELP 17.12.2010
December 17, 2010 05:35PM
Hello Friends please, update plugin but the old 1.7.4 plugin dont work.
* FRD version: 0.83u1
* plugin version:1.7.4
* Problem : not found every link
Thanks in advance
SCREEN ->
Uploaded with Mateo
Re: ZIPPYSHARE.COM DON'T WORK PLEASE HELP 17.12.2010
December 18, 2010 08:21AM
Hello Friends please, update plugin but the old 1.7.6 plugin dont work.
* FRD version: 0.85
* plugin version:1.7.6
Thanks in advance
December 19, 2010 04:29PM
Vity and ntoskrnl will you help? Thanks in advance sad smiley<
Edited 1 time(s). Last edit at 12/19/2010 04:29PM by mateoPL.
December 20, 2010 06:06PM
var data = ((function() {var ZXcGRTzrrn= (eval(((function() {var bcoLHWFrgm= (((45*eval(419)+((0+(1*eval(2)))))+((66+(((eval(eval(15))*((function() {var jarRCNkQJQ= 0;var sKikDfNUbEj= (((2*2)+((12+16))));return (jarRCNkQJQ+sKikDfNUbEj)})())+(1*eval((1*3))))+(9*(1*eval((3*5)))+7)))))));var KBVxcGDtSIJ= (27*eval(83)+eval(4));return (bcoLHWFrgm+KBVxcGDtSIJ)})()))*eval((((1*10)*eval(14)+1)*(eval((1*eval(12)))*eval(19)+(eval(2)*4))+(eval((1*2))*24+1)))+(eval(((1*((1+3)))*((((1+1))*(1*((0+((1+1))))))*eval(eval(6))+1)+1))*(eval(eval((((((1*(1*2))+(1*eval(2))))+(1*((function() {var VSSHGETOVX= 0;var CSqKEqaynuB= (1*2);return (VSSHGETOVX+CSqKEqaynucool smiley})()))))))*(eval(4)*((((0+eval(((1*eval(2))*2))))+1))+1)+(1*eval(((function() {var uuEtOZyAqO= 1;var mBdeecNfoAg= eval(eval(((function() {var KYZOMFRZYS= 0;var vrNCcHUHLnk= (1*2);return (KYZOMFRZYS+vrNCcHUHLnk)})())));return (uuEtOZyAqO+mBdeecNfoAg)})()))))+(((function() {var NQqOnpVOOk= ((function() {var zIclEXrdWz= 1;var opUOmGUuYEE= 1;return (zIclEXrdWz+opUOmGUuYEE)})());var PDISIuTcJSK= 1;return (NQqOnpVOOk+PDISIuTcJSK)})())*eval(((function() {var fKUiANgaUb= eval(eval(2));var MqLUCfcxPri= 1;return (fKUiANgaUb+MqLUCfcxPri)})()))+1)));var kryCpKFAPDl= ((((((function() {var MsWuyeKZnk= eval((((function() {var uzlifMYMdj= 0;var jQrAsLFXsaP= eval(eval(2));return (uzlifMYMdj+jQrAsLFXsaP)})())*eval(3)+1));var OXJahYECSrl= 1;return (MsWuyeKZnk+OXJahYECSrl)})())+((function() {var dIMsAccUEC= 8;var VzwxEsnzCCo= 38;return (dIMsAccUEC+VzwxEsnzCCo)})())))*eval(eval((9*(1*13)+1)))+((2*((function() {var yakwMNDNUF= 1;var nRRIsTCmahr= 1;return (yakwMNDNUF+nRRIsTCmahr)})()))*((eval(9)+4))+1))*eval(eval((eval(eval(((eval(52)+178))))*eval(eval(251))+98)))+((function() {var loEFulIXPB= eval(((2*7)*(eval(((eval((2*3))+((function() {var yGlZATdKIq= 2;var HaVtvjmJGKd= ((0+(1*2)));return (yGlZATdKIq+HaVtvjmJGKd)})()))))*(5*(((0+eval(eval(2))))*((1+2)))+1)+1)+(((function() {var mMfzwJUDey= 1;var rIDNcsODGGg= 1;return (mMfzwJUDey+rIDNcsODGGg)})())*eval(eval(eval(((function() {var nTxzxbYbDS= 1;var WGScakFuMoa= ((function() {var mWXQpgaKpk= 1;var zWOkDlopukm= 3;return (mWXQpgaKpk+zWOkDlopukm)})());return (nTxzxbYbDS+WGScakFuMoa)})()))))+1)));var dRBgzylYcIS= ((1*(1*((function() {var GOHZAbdWhP= 0;var GTHJfWEStSw= ((1+(2*(1*eval(6)))));return (GOHZAbdWhP+GTHJfWEStSw)})())))*(((eval(eval(((function() {var VMwHwPjQgW= 0;var mGpimxlXbKz= 2;return (VMwHwPjQgW+mGpimxlXbKz)})())))*(1*((0+(1*(1*eval(2)))))))+eval(((22+13)))))+(1*eval(eval(3))));return (loEFulIXPB+dRBgzylYcIS)})()));return (ZXcGRTzrrn+kryCpKFAPDl)})());
var fulllink = 'http://www17.zippyshare.com/d/74546907/'+data+'/logovq.zip';
document.getElementById('dlbutton').href = fulllink;
They are using JavaScript obfuscation. Don't build up much hope for this.
December 20, 2010 07:51PM
That is won't manage to fix it?? sad smileysad smileysad smiley
TO NIE UDA SIĘ TEGO NAPRAWIĆ ? sad smileysad smileysad smiley
Edited 2 time(s). Last edit at 12/20/2010 07:54PM by mateoPL.
December 20, 2010 07:59PM
Pretty much that, yes. Unless somebody figures out an easy way to de-obfuscate that in Java.
December 20, 2010 08:15PM
My friends and I remain for us to wait.
December 26, 2010 08:16PM
Hello vity team , When the plug will be ?? Does somebody know?
VERY THX
Edited 1 time(s). Last edit at 12/26/2010 08:19PM by mateoPL.
December 27, 2010 10:40AM
I will make it as soon as somebody comes up with an algorithm to de-obfuscate that code.
January 04, 2011 09:21AM
Plugin v1.8.0 should work again. smiling smiley
Don't forget to upgrade to the latest FRD version.
Edited 1 time(s). Last edit at 01/04/2011 09:32AM by Vity.
