ad.fly and others
Posted by andreasabe
ad.fly and others
April 06, 2012 02:01AM
Make a filter so if there is a link like this: [adf.ly] in the new urls insert - paste from clipboard (usually i use drag and drop to add my links), the program will only get the [www.mediafire.com] part, you dont need the ad.fly, because the link is there, ins't masked!
Re: ad.fly and others
April 06, 2012 12:44PM
This is a problem (or feature) with clipboard monitoring in the main program. It looks through the clipboard for "http://" and splits each instance into a link. These links are then matched against each plugin to see whether they are supported. Your example link is split into "http ://adf.ly/500607" and "http ://www.mediafire.com/?mxxxxxxxxxxxxxx", both of which are supported by plugins.
We will see what we can do about it. For now, you can disable clipboard monitoring for the adf.ly plugin in Options > Preferences > Plugins.
