I will show you how easy is to add your links from browser to FRD, you don't even need to see whole links "http://...." on screen!
1. First, check clipboard monitoring in FRD - in menu Options->Clipboard monitoring is checked
enable clipboard monitoring is indicating this active icon in statusbar (btw. did you know that this icon is clickable?
2. Go to the browser
and select by mouse links you want to add:
3. Press Ctrl+C to copy selection into clipboard (you can alternatively use right mouse button -> copy to clipboard in your browser)
4. FRD window with your selected links is activated:
5. Press Start to begin download
Edited 4 time(s). Last edit at 11/07/2009 06:48PM by Vity.
