Paste issue
Posted by Vadko
Paste issue
March 13, 2011 01:49AM
Is there a way of when pasting expressions with exponents and subscripts copied from HTML or rtf to wordrider that formatting is maintained?
I'm not programming savvy, but it seems like a small bug to fix.
Can anybody help please?
Re: Paste issue
March 13, 2011 07:03AM
I don't understand what you want.
Re: Paste issue
March 13, 2011 01:29PM
When I copy an expression like 1.5*107, x2+y3 or V0 V1 from an html page or a rtf document and paste it ito wordrider it becomes 1.5*107, x2+y3 V0 V1 - it loses the exponent and subscript formating. Its possible to fix it?
Re: Paste issue
March 13, 2011 03:00PM
No.
Re: Paste issue
March 13, 2011 03:27PM
Since you can't fix it, and the source code is available.
What aproach would you suggest if I would like to try to fix this bug myself?
Re: Paste issue
March 13, 2011 03:38PM
It's not possible to fix it.
Re: Paste issue
March 13, 2011 05:13PM
No? What a pity, It sure seemed like a simple issue.
A bit off topic, are you thinking in releasing a new version that might address this issue?
Re: Paste issue
March 13, 2011 05:15PM
If you think it's easy - good luck with it. winking smiley
No. WRD development has been stopped.
Re: Paste issue
March 13, 2011 05:18PM
It seemed easy, but for sure its not :)
Even with the development stopped, thanks for the development you did.
