Links are not copied to dashboard
medea
medea
February 04, 2014 11:15AM
Having this issue since yesterday.
When I copy a link, it's not added to the clipboard as it was before. So I have to go to FR and paste them manually.
Re-installed Java, disabled all the browser plugins with no luck.
Please, advise
ntoskrnl
Re: Links are not copied to dashboard
February 04, 2014 02:57PM
Admin
Is clipboard monitoring enabled? Options > Clipboard Monitoring.
The clipboard icon in the status bar also toggles this setting.
medea
February 04, 2014 05:14PM
That solved the problem, thanks
