Recycle Bin
Posted by jmnduc
Recycle Bin
January 14, 2015 05:28PM
I just wanted to say "thank you" to anyone who have the great idea for the "Ctrl+L" (Remove Completed Links + Delete Files), it wiped out everything I did.
You could have at least move to the Recycle Bin, it would have helped me recover mistakenly pressed buttons.
So could you please rethink of such simple suggestion?
Thank you very much.
Re: Recycle Bin
January 14, 2015 05:34PM
There is an option to use the recycle bin, though it's not enabled by default. See Options > Preferences > Misc.
Re: Recycle Bin
January 14, 2015 06:49PM
You are welcome.
Just a note, it is "Remove completed links and deleted files". It does NOT delete anything on the disk. It just removes links whose files are NOT already present on the disk.
Edited 4 time(s). Last edit at 01/14/2015 07:59PM by Vity.
