FRD doesn't run. Something with Java machine?
January 29, 2009 01:37AM
Hello.
Vity, thank you for your program. It's useful and convenient.
But I've got problem with running FreeRapid.
Everything was fine, but once FRD shown me the error message. I've tried to restart it, but frd didn't start anymore. When I run it, I can see the splashscreen, then nothing happens. I have feelings, that program "Kleptomania" I installed and tried to use made some changes in system. Now I can run no java applications, except java applets in web browser.
app.log:
29.01.2009 3:26:23 cz.vity.freerapid.core.AppPrefs loadProperties
CONFIG: Config files directory: C:\Documents and Settings\Mikhail\Application Data\VitySoft\FRD
29.01.2009 3:26:23 cz.vity.freerapid.utilities.Utils getAppPath
CONFIG: App Path is C:\Program Files\FreeRapid
29.01.2009 3:26:23 cz.vity.freerapid.core.Lng loadLangProperties
CONFIG: Setting locale ru_RU
29.01.2009 3:26:23 cz.vity.freerapid.swing.LookAndFeels initClassLoader
INFO: Loading plugin path C:\Program Files\FreeRapid\lookandfeel
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/JTattoo.jar
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/kunststoff.jar
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/PgsLookAndFeel.jar
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/squareness.jar
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/substance-lite.jar
INFO: Loading URL with a jar file:/C:/Program%20Files/FreeRapid/lookandfeel/substance-swingx.jar
When I try to start frd with command "java -jar frd,jar", the message follows:
Caused by: java.lang.IllegalArgumentException: 53687091 incompatible with Text-specific LCD contrast key - the same error message I recived from frd the last time it worked correctly.
PS OS WinXP SP3 PRO, Java Sun JAVA machine ver. 6 11, frd ver. 0.81
PPS I'm sorry for bad English
PPPS Thank you for answers.
Re: FRD doesn't run. Something with Java machine?
January 29, 2009 01:59AM
Sorry for disturbance, I've solved it myself.
If anybody have the same trouble, here the solvation is. This is the bug in Sun Java Machine under Windows. And yes, the program, that changed truetype settings was kleptomania.
February 03, 2009 10:03AM
Hello,
I have the same problem with frerapid and java. What exacly is the solution? Which registry entries have I to change for java fonts?
February 03, 2009 02:01PM
Download an install Microsoft powertoy "Cleartype Tuning"
It forces right values for fonts.
February 04, 2009 09:45AM
Thanks for help. I have installed "ClearType Tuner" and what I have to do? Set "Turn On Clear Type" indicator? I don't want to use cleartype fonts.
