Extabit premium, need help please
January 09, 2013 09:00AM
Hi guys, my first post...
My Extabit premium plugin don't work at all (the account works "fine" on the navigator). Can someone, please, gimme some help?
Edited 1 time(s). Last edit at 01/09/2013 09:02AM by Zulu_br.
Re: Extabit premium, need help please
January 09, 2013 08:43PM
the Extabit premium plugin has a very simple implementation
the most likely problem could occur logging into extabit (check your user/pass)
or reading information from the extabit web page {error messages, download link, ...}
post your app.log after the problem occurs (Help -> Browse to log file)
"don't work" == useless description. reporting plugin problems
January 09, 2013 11:09PM
Sorry, it was my first post, I wrote it before reading the "rules"(maybe a common mistake). Thanks for replying(and for creating the plugin too).
But there's no error, it says on ETA column: "obtendo"('cause it's in portuguese and it means "getting it") but nothing happens. I'm using uploaded and rapidgator premium as well and they are working fine. I've checked links, pass, everything that a dumb man as I can. Will try this way: I'm gonna stop all other, reiniciate and then post the log, ok?
Thanks for your concern.
Edited 1 time(s). Last edit at 01/09/2013 11:09PM by Zulu_br.
January 09, 2013 11:15PM
Wed Jan 09 21:12:08 BRST 2013 WARNING: Text content type expected, but binary stream was found
This is everything that's in the log. When I open the link in the browser, it starts to auto download.
January 09, 2013 11:42PM
The plugin either finds the extabit provided link to download or gets the direct download that starts automatically
something to test :
log into your extabit account on the website
and see if changing the direct download setting makes a difference in freerapid
January 10, 2013 12:07AM
I tried, but I can't change in the direct download because(I think) the account is rented...
If I erase the provided link from the list and then open the link in the browser, the plugin will get the aotu download?
January 10, 2013 12:24AM
the account may not be premium ??
changing the option changes how extabit provides the download
depending on the option the plugin handles the download differently in freerapid (not browser)
January 10, 2013 12:49AM
I'm sure the account is premium, cause I can, through the browser, download multiple files, and the site tells me that is a premium account.
Well, now it is working with only one premium file, and there's others in the "getting". Still... people are saying in a lot of forums that extabit is trash...
Thank's a lot birchie for your help!!!
January 10, 2013 06:58AM
The plugin doesn't support direct downloads. You'll have to disable that option on the ExtaBit site.
January 10, 2013 08:19PM
Yes it does!
