Problem Czech TV - download
November 04, 2023 09:24AM
Good day,
could I please request to modify the plug-in to allow downloading from the website [www.ceskatelevize.cz].
Until recently, the download was possible, but now it no longer works.
For example: [www.ceskatelevize.cz]
Error message: Failed to parse playlist
In advance Thank you very much for the edit
Pucma
Re: Problem Czech TV - download
December 20, 2023 04:04PM
Hello, someone please help with Ceska Televize plugin...
Someone please help!
Edited 1 time(s). Last edit at 11/01/2024 12:30PM by ha_pi_pi.
January 27, 2024 01:32PM
I was trying to get some bedtime fairy tails for my children, since uloz.to is dead and found some of them on ceskatelevize.cz iVysilani I wanted to use FreeRapid Downloader. Strangely enough some links are working ok and some, I am sending examples:
Working
Not working:
Those that does not work fails with error "Failed to parse playlist"
I am using ceskatelevize.cz plugin version 2.2.1
Is there still someone who can help to fix the issue?
TOB
May 15, 2024 12:08PM
Dobrý den,
dnes jsem se po dlouhé době pokusil něco stáhnout, ale bohužel hlásí to stejné chyby jako píší výše uvedení uživatelé.
Používám plugin ceskatelevize.cz verze 2.2.1
Bylo by možné, aby někdo tento problém odstranil?
Nebo co je třeba udělat proto, aby se dalo z těchto stránek stahovat?
Díky
TOB
July 25, 2024 12:59AM
Plugin 2.2.1 sometimes doesn't work, and returns an error message "Failed to parse playlist"
FRD version: 0.9u4
Examples:
(This is an example that works well:
Edited 1 time(s). Last edit at 07/25/2024 01:00AM by Izibia.
open | download - app.log (6.3 KB)
September 10, 2024 04:53PM
Also for this it shows Failed to parse playlist:
But ie this is OK.
open | download - app.log (8.1 KB)
November 01, 2024 12:39PM
Ahoj!
Neuvěřitelné se stalo skutkem a Česká Televize vystavila na internet staré řady pořadu StarDance!
Vždy předtím byla k dispozici jen aktuální řada, a někdy v polovině ledna následujícího roku už pořad nešel přehrát, protože vypršela práva, či co. Nyní je k dispozici všech 13 řad v HD kvalitě! Nikdy jsem neměla 1. sezónu možnost ani vidět, natož stáhnout, FRD zafungoval a rané řady, jako první a nebo druhá, stáhnout LZE!smiling smiley
Bohužel aktuální řady, jako je ta letošní, nebo dvě zpátky dozadu, stále hlásí Eror Failed To Parse Playlist.
Někdo ví, čím to je? Prosím, odpovězte. Program i plugin České televize si udržuji aktuální. Děkuji.
Hello,
I've been trying to download czech version of Strictly Come Dancing, called Stardance, for years now.
It comes with the error "Failed To Parse Playlist". Recently all the seasons since 2006 became available for stream. Early seasons seem to be donwloadable without any error, like 1st or 2nd. The latest 3 season stick with the "Failed To Parse Playlist" error. Anyone willing to figure this out, make a plugin Fix? Thanks for any try.
Note: The program is playable only from czech VPN. It won't play if you connect from other country!
Edited 1 time(s). Last edit at 11/01/2024 12:42PM by ha_pi_pi.
open | download - app.log (1.07 MB)
January 09, 2025 10:27PM
Ahoj
všechna stažená videa obsahují hlášku o nepodporování aplikace a o doporučované aktualizaci. Viz přiložený screenshot. Uměl by prosím někdo updatovat plugin pro českou televizi?
Moc děkuju
Tom
open | download - Snímek obrazovky 2025-01-09 232345.png (786.1 KB)
January 10, 2025 01:45AM
FRD gets different file instead of downloading the file with the desired video.
Posting the link with short vid for anyone to test.
Re: ČT ERROR - zastaralá aplikace
January 10, 2025 03:55PM
Jo jo, nejde to, děkuji předem pokud se na to někdo podívá. Snad to půjde "opravit" smiling smiley
Yep, doesn´t work. Thanks for possible fix. I hope it can be fixed smiling smiley
