Deleted by error when i delete oder link for same files
Posted by atunoa
April 18, 2010 03:01PM
I haved downloaded, by security, to different link for security (if one don't work or is to slow, i have an oder without any search) for a group a files.
When i have finished all the 35 downloaded files, in 3 days!, with kaptcha!, i have deleted the oder links... and i delete definitively all my work!!! No solution to restore.
Except this problem, i'm very entousiast with this prog. Its for me the best and i have tested many more, and i don't want to change.
Thanks for your excellent job!
Re: Deleted by error when i delete oder link for same files
April 18, 2010 03:06PM
I think this is the same bug as here: [wordrider.net]
Vity, could you take a look at it?
April 18, 2010 03:12PM
It's on the (long) list
April 18, 2010 03:22PM
If there are some simple tasks needing to be done, I could probably help. Only if it's OK to you of course.
