Setting all plugins to a max of 4 downloads
Posted by slickrcbd
December 12, 2018 11:14PM
Is there a way I can edit the config file with something like Notepad++ or HexEdit to do a global search & replace for every plugin that supports 10 or 100 simultaneous downloads and replace every 10 and 100 with a 4 to limit it to 4 maximum?
I run FRD in the background and want to limit the connections, but there are tons of plugins.
If there isn't, is there a way to copy the configuration I had for the plugins on my old Windows 7 computer to the brand new Windows 10 computer? Just about every site I've used has been modified on the Windows 7 computer if it had more than 4 downloads.
I'm not sure what file to copy or where it is located. I copied the entire FRD directory when installing it on Windows 10.
If the UI has something built-in to do this other than one plugin at a time, please tell me how to use it.
Thank you.
Re: Setting all plugins to a max of 4 downloads
December 13, 2018 06:38AM
Ad first question - No.
The FRD configuration is located here: [wordrider.net]
December 14, 2018 07:13AM
You can limit the overall connections by setting "Preferences > Connections Tab > Max concurrent downloads" to 4.
Anyone can create & fix plugins
