jumbofiles plug-in problem
Posted by spammehere
June 16, 2012 09:43PM
I entered username and password into jumbofiles plug-in
And later i'd like to erase them, but it could not been done
It always asked me to enter something
How can I erase username and password from jumbofiles plug-in?
Re: jumbofiles plug-in problem
June 16, 2012 09:54PM
you cant erase them in FRD
to erase the details go to folder (change USERNAME to your computer username)
c:\Users\USERNAME\AppData\Roaming\VitySoft\FRD
and delete the file "plugin_JumboFiles.xml"
June 16, 2012 10:15PM
Thanks birchie
I didn't find the file/folder what u mentioned in my PC
But I did find a file, jumbofiles.frp, at the plugins folder
and i deleted it
everything is fine now
Thank you
June 16, 2012 10:28PM
oops! my bad
Deleting jumbofiles.frp didnt slove the problem
so I searched again
and I found "plugin_JumboFiles.xml" at the c:\Documents and Settings\username\Application Data\VitySoft\FRD" folder
and deleted it
NOW everything is fine
Thank again
BTW, I am using Windows XP
June 16, 2012 11:01PM
Your Welcome, older OS... different hiding place
jumbofiles.frp is the plugin - undelete, or update plugins when you restart FRD
Edited 1 time(s). Last edit at 06/16/2012 11:07PM by birchie.
