dailymotion.com doesn't work
Posted by ATom
October 09, 2012 06:29PM
Tested with: 0.86u1
And this url: [www.dailymotion.com]
It display this error: No string between '.addVariable("sequence, "and'" was found - attempt 1
Re: dailymotion.com doesn't work
October 11, 2012 06:19AM
You're not using the latest version of the plugin (v1.1.8), please update.
October 11, 2012 07:48PM
Thanks. I probably must update whole frd, because it doesn't detect any new version of this plugin for me.
October 12, 2012 05:17AM
0.86u1 is the latest version of FRD, and the plugin should be 1.1.8.
October 20, 2012 08:40AM
Dailymotion plugin v1.2.0 now supports :
- quality selection
- playlist, for example : [www.dailymotion.com]
- group, for example : [www.dailymotion.com]
- downloading subtitle, for example : [www.dailymotion.com]
Enjoy smiling smiley
October 20, 2012 01:14PM
tong you are the man thumbs up smiley
October 22, 2012 02:51PM
I'm getting following error message since this morning:
ERREUR - Le fichier n'est plus disponible (file unavailable)
app log: WARNING: No subtitles found
Sample: [www.dailymotion.com]
Edited 1 time(s). Last edit at 10/22/2012 02:53PM by lechuck.
open | download - app.log (1.2 KB)
October 22, 2012 03:16PM
Thanks for the report.
They add widget that causes "File not found" false positive error message.
Fixed in plugin v1.2.1.
October 22, 2012 03:19PM
wow fast :) Thanks a lot.
October 30, 2012 09:56AM
hi, I have slight problem with french accents in filenames with 0.9beta1 and 2. But maybe it's specific to FRD..
e.g. [www.dailymotion.com] renamed zapping t_u00e9l_u00e9 du 30.mp4
Edited 2 time(s). Last edit at 10/30/2012 09:58AM by lechuck.
open | download - frd.jpg (7.8 KB)
