flickr plugin - how does it work?
October 18, 2012 12:25PM
i'm quite new to FDR and still didn't understand how plugins work exactly... just used the facebook one to download albums - successively
when trying to ddownload a flickr.com album it just does nothing... i add the URL, it apears in the list and when i start it it just disappears and nothing is downloaded... am i doing something wrong?...
i also don't find any post on this forum about the flickr plugin...
Re: flickr plugin - how does it work?
October 19, 2012 09:35AM
Please try flickr.com plugin v1.1.0. It now supports :
- Photosets, for example : [www.flickr.com]
- Galleries, for example : [www.flickr.com]
- Favorites, for example : [www.flickr.com]
- Videos, for example : [www.flickr.com]
You have to disable flickrcollections.com plugin, and use flickr.com plugin instead.
October 19, 2012 09:48AM
thumbs upsmileys with beer
October 19, 2012 10:40AM
thanks for updating the plugin...
something not working with urls like:
[www.flickr.com]
[www.flickr.com]
This error appears on the Est. Time column:
ERROR - No number between '"pages":' and ',' was found
not sure what it means by that...
October 19, 2012 11:52AM
Flickr plugin v1.1.0 works fine in FRD 0.9beta, but is broken in FRD 0.86u1.
Please try flickr.com plugin v1.1.1. It should works for both FRD version.
