Novafile.com Premium problem
Posted by Mano
January 07, 2013 05:03PM
Hey there,
I added an account to the novafile plugin and now i receive this error: "Tag with a name or ID 'FL' was not found"
and a little bug or at least i dont know how to do it, if i want to remove the user i cant because it must be something written in the box.
any ideas?
Thanks!
Re: Novafile.com Premium problem
January 08, 2013 09:02PM
to remove the premium account details delete the file "plugin_novafile.xml" from the FRD folder
depending on windows version, FRD folder is either
c:\Users\USERNAME\AppData\Roaming\VitySoft\FRD
c:\Documents and Settings\USERNAME\Application Data\VitySoft\FRD
January 08, 2013 09:07PM
it works now, thanks!
