PROBLEM WITH THE CHANNEL 5 PLUGIN WHEN I DOWNLOAD PLUGIN NEEDS TO BE FIXED
Posted by barryz
February 03, 2013 11:24AM
PROBLEM WITH THE CHANNEL 5 PLUGIN WHEN I DOWNLOAD A CHANNEL 5 PROGRAM IT SAYS 1KB WHEN I CHECK THE FILE SIZE IT IS ONLY 1KB WHICH IT WRONG IT DOES NOT DOWNLOAD ANY SHOWS ANYTHING YOU DOWNLOAD OFF CHANNEL 5 SITE IT JUST SAYS 1KB FILE THIS PLUGIN NEEDS TO BE FIXED SO THAT IT CAN THEN DOWNLOAD CHANNEL 5 PROGRAMS.
Edited 2 time(s). Last edit at 02/03/2013 11:32AM by barryz.
Re: PROBLEM WITH THE CHANNEL 5 PLUGIN WHEN I DOWNLOAD PLUGIN NEEDS TO BE FIXED
February 03, 2013 12:45PM
Is you caps lock key broken? Maybe you should fix it first. FRD cannot work with broken caps lock key.
