Datafile doesn't work
May 15, 2013 09:57AM
I have problems to download files from DataFile and all services that are shown with the same icon (in FreeRapid). I simply get this error message: ERROR STARTING DOWNLOAD. Can somebody help me, please? Thanks in advance.
Re: Datafile doesn't work
May 16, 2013 02:28PM
I'm not sure if I fully understand your post. We don't have plugin for DataFile.
Please attach app.log.
May 16, 2013 08:13PM
My friend,
Thanks for trying to help me.
I did not know you do not have plugin for Datafile. However, the program add links from this server normally.
I have attached the log file plus a picture of the error message that I get. Please pay attention to the icon for the service. I get the same message for every service that displays this icon in the program.
I hope you will find a solution.
Thanks in advance!
open | download - app.log (214 bytes)
open | download - app.PNG (20.8 KB)
May 17, 2013 05:21AM
That icon means the program is trying to download the link directly. If you have direct downloads enabled in Options > Preferences > General, FRD will consider all unrecognized links as direct downloads.
May 19, 2013 10:53AM
Thanks for your care.
This option is already enable and I is still not possible to download.
Maybe there is something missing for Datafile server...
How can we solve this matter then?
Thanks for your help!
May 19, 2013 10:57AM
You can disable the option if you don't use the direct download feature.
It will obviously fail for links that are not direct downloads (such as DataFile links).
FRD needs a plugin for DataFile if you want to download files from that service.
May 20, 2013 09:51PM
Maybe it is really necessary to provide a plugin for DataFile.
Is it possible?
May 24, 2013 10:50PM
DataFile.com plugin created cool smiley
