fireget.com problem
Posted by mac23
fireget.com problem
July 14, 2013 05:12PM
Hi. This plug-in has stopped working. The error is "file name not found ", but file size is displayed correctly and file can be downloaded from the browser as well.
I'm using FreeRapid Downloader .9u2 with fireget.com version 1.0.1 plugin. (premium account)
Thanks a lot for fixing this issue.
And quick question: is it possilble to change premium account back to free? There is a message:"You have to fill user name please".
Re: fireget.com problem
July 14, 2013 09:45PM
The plugin works fine for me (as a free user)
Please provide the app.log file (Reporting problems) or (Fixing premium plugins)
To remove premium account details
"Help > Browse to log file" takes you to folder ".....\FRD\log\".
In the FRD folder delete file "plugin_FireGet.xml" to remove premium account details
July 15, 2013 08:37PM
Thanks for advise, free account works fine...but premium still with issue "file name not found".
In attachement app.log file.
Thx for help.
open | download - app.log (16 KB)
July 15, 2013 10:27PM
plugin v1.0.2 should fix premium "file name not found" issue. [fingers crossed]
July 16, 2013 07:28AM
Different error mesage: "File size not found", but size is displayed correctly. Other thing, instead of name of file in Name column, just "" is shown. (premium account)
July 16, 2013 08:33PM
this time plugin v1.0.3 should work
July 17, 2013 09:00PM
yes, thanks a lot, now it's working. great job!
