ask help-software caused connection abort
July 28, 2013 08:16AM
I am the first time to use freeRepid Downloader,but when I am downloading the files after submitting the address, downloading can not be continued and shows "software caused connection abort:recv faild". How can I solve this problem? Thks!
Re: ask help-software caused connection abort
July 28, 2013 01:04PM
Can you download with your browser? Maybe antivirus or firewall software causes it? If you are using a proxy, are you sure it works properly?
July 29, 2013 07:24AM
Thank you for your kind reply. I can not use the browser get downloading because the website can not be visited. I also try use freeRapid downloader after closing the antivirus or firewall software ,but still have the same problem mentiond above. when I use a proxy visit the website such as uploaded.net to download the files, the examination code can not be displaied, so still the downloading processing can not be continueed.
July 30, 2013 03:24PM
FreeRapid emulates a browser – if you cannot download with your browser, then FRD cannot download either.
