My Putlocker plugin doesn't work confused smiley
Posted by ratooz
October 10, 2013 05:58AM
Hi.. I need help.
It's been a while I can't download ANYTHING from Putlocker to my computer. I always get endless waitings. This is happen since version 0.86.
I'm now using FRD 0.9u3 with Putlocker plugin version 1.2.0.
I've tried with other computers and all Putlocker links worked fine, no problem.. So I assume there is something wrong with my computer settings or whatever.
Need Advice.
Here's a sample link : SAMPLE
open | download - app.log (1.1 KB)
Re: My Putlocker plugin doesn't work confused smiley
October 10, 2013 11:32AM
Your link works fine for me.
Does it happen only for putlocker or all plugins ?
From your log, it seems that something blocks FRD. Most probably firewall or antivirus, please put FRD in the firewall/antivirus whitelist.
October 10, 2013 01:00PM
Yeah, nothing wrong with the link since I've tried it on other computers, they all fine.
I have no problem with other plugins, they're great, just putlocker has this problem, which puzzles me. All this time I had to use other computer to download files from putlocker.
I've tried put it in exception list of my AV (AVIRA) but still doesn't work. I've tried also delete the plugin file (putlocker.frp) and download a new one since I thought Its broken but still a NO NO :(
Edited 1 time(s). Last edit at 10/10/2013 01:01PM by ratooz.
October 10, 2013 01:06PM
Try to uninstal the antivirus.
October 10, 2013 02:34PM
@ratooz : this is weird, your log says it failed to connect to wordrider.net, yet you managed to update the plugin. Anyway I just released plugin v1.2.1. Let us know how it goes.
October 11, 2013 11:24AM
I don't have problem updating the plugins.
I have removed my antivirus like Vity suggested, update the plugin to 1.2.1 but still a big NO.
Only putlocker has the problem, others don't... I begin to think putlocker hates me personally. This is CRAZY.
here's my app.log after update to 1.2.1.
Edited 1 time(s). Last edit at 10/11/2013 04:25PM by ratooz.
open | download - app.log (1.4 KB)
October 24, 2013 10:30AM
Sorry for the very late reply, I had to sort out something.
It seems that you have a broken/corrupted putlocker plugin, and have the direct download feature enabled.
I just released plugin v1.2.2 to fix weird issue in URL pattern, but it had nothing to do with your issue. Anyway please try it.
If the issue persists, please try the attached plugin, or you can copy a working putlocker plugin from your other computer. Copy the putlocker plugin to FRD plugins folder.
If the attach plugin doesn't work, please post app.log in debug mode. To run FRD in debug mode :
Windows OS: frd.exe --debug
Linux/MacOS: java -jar frd.jar --debug
Edited 2 time(s). Last edit at 10/24/2013 10:34AM by tong2shot.
open | download - putlocker.frp (10 KB)
October 25, 2013 06:39AM
@tong2shot
Thanks for the reply, man.. smiling smiley
Sadly, the new plugins (both) don't help :( ... I tried again with the direct download option switched to ON and OFF but still the same result came out.
Here is the link I tried >> link
the app.log with debug mode is in the attachment.
Edited 1 time(s). Last edit at 10/25/2013 09:57AM by ratooz.
open | download - app.log (24.5 KB)
October 25, 2013 01:30PM
I can download the file just fine.
There is a slight difference between your log and mine.
Please try the attached plugin.
As usual, if it doesn't work please attach app.log in debug mode.
What country are you from ? Are you using proxy ? Can you download the file via browser ?
open | download - putlocker.frp (10.1 KB)
December 13, 2013 07:33AM
@Tong2shoot
I apologize... I've been busy at work.
What country are you from ? > I am from Indonesia
Are you using proxy ? > Not that I know
Can you download the file via browser ? > No I Can't (Putlocker only)
It seems my provider somehow blocked by Putlocker (maybe, I don't really know, an amateur guess - I'm next to a dummy for this kind of thing).. the other computers using different operator and they worked.
A friend advice me to use Hotspot Shield (www.hotspotshield.com).. it worked, but for a moment. I only able to download one file/part.
Anyway, I already found another source for the files and complete the download.. I guess I just have to stay away from Putlocker now. :)
Thanks again for your time. GBU smiling smiley
Edited 1 time(s). Last edit at 12/13/2013 07:48AM by ratooz.
