Ultramegabit plugin problems
Posted by vellencw
October 18, 2013 07:41AM
FRD version 0.9u3
Ultramegabit plugin version 1.0.2
It works to download the first file, but then the rest of the links turn to "file is not available anymore" and it won't go on to the next file. Validating the links shows they are fine, but resuming the downloads invalidates them again. After waiting awhile (not sure how long) I can download the next link, but afterwards the process just repeats itself. Here are some links from my queue:
[ultramegabit.com]
[ultramegabit.com]
[ultramegabit.com]
[ultramegabit.com]
Thanks!
Re: Ultramegabit plugin problems
October 22, 2013 02:43AM
Looks like they've changed the ultramegabit site now, so all I get is "File Name/Size not found" on all those links in FRD. Although the previous issue was with download limits, now the plugin is not functioning at all.
October 22, 2013 04:22AM
unsure why the 1st problem was happening, it has a wait between downloads, I couldn't get the file not found errors
2nd problem - plugin fixed to work with the new page layout
October 22, 2013 05:25AM
Just got the new plugin version, and it appears to be working fine! Thanks so much!
October 28, 2013 04:08AM
Looks like they changed the website again. Could you please update the plugin?
Thanks!
October 28, 2013 10:24PM
plugin fixed
