Videoweed CHYBA - Parameters not found (1)
November 08, 2013 05:31AM
Using latest FRD version 0.9u3
videoweed plugin 1.2.0
link example [www.videoweed.es]
Prosím o vyřešení, pokud je chyba nějakým způsobem na mé straně, nebo už byla jinde hlášena, omlouvám se.
open | download - app.log (386.6 KB)
Re: Videoweed CHYBA - Parameters not found (1)
November 08, 2013 12:33PM
Plugin v1.2.1 should work again.
November 08, 2013 03:54PM
Yes, it does work. Thanks a lot for the quick fix!:)
June 24, 2014 05:33AM
The plugin downloads the file, but without an extension (flv).
Can this be fixed?
Sample - [www.videoweed.es]
Also support for embed URLs will be nice - [embed.videoweed.es]
June 29, 2014 12:49AM
Thanks for the report.
Plugin v1.2.2 fixes extension bug and supports embedded URL.
July 02, 2014 04:54AM
Thanks a lot tong :)
July 17, 2014 01:19PM
Many countries have started banning hosting sites such as videoweed, movshare and divxstage.
