Problem with lumfile
superduper
superduper
December 26, 2013 01:03PM
lumfile.com 2.0.5
In the past I had a premium account for lumfile but not now anymore. However I cannot leave username and password blank as it will give an error.
Is this a bug?
ntoskrnl
Re: Problem with lumfile
December 26, 2013 01:07PM
Admin
It's a feature.
You can delete the LumFile configuration file, which will clear the login details. Help > Browse to log file, then go up one directory level. You should see "plugin_LumFile.xml". Delete that and restart FRD.
superduper
December 27, 2013 03:23PM
Thanks ntoskrnl
That did the trick
