Rapigator Premium Plugin Problem
Posted by Sa9aX
December 31, 2013 10:52PM
Hi
I been having problems with rapigator.net_premium plugin & links:-
1. FRD error message says "DISABLED: plugin null is not enabled", I checked in the preference - plugins it is enabled & password is set right. As for rapidgator.net plugin it works ok.
2. Rapidgator links sometimes it doesn't capture to send to FRD (Clipboard monitoring) also tried clicking entering to rapidgator web site still doesn't capture, it only happens to most rapidgator links other ones work (Letitbit, Turbobit, Uploaded, etc.) are ok. Switching off Avast! didn't help.
Log say this:-
Wed Jan 01 08:02:12 EST 2014 WARNING: No Content-Disposition (filename) header in file
Wed Jan 01 08:02:12 EST 2014 WARNING: No Content-Length in header
Wed Jan 01 08:02:12 EST 2014 WARNING: Loading file failed
My Versions:-
FRD version 0.9u3
rapidgator.net_premium 1.1.1
rapidgator.net 1.1.9
Sal
Re: Rapigator Premium Plugin Problem
January 01, 2014 12:14AM
F#@K, my bad sad smiley
typo when adding rg.to support to the plugin
fixed now - update your plugins (help > check for new plugins)
