strange chars on filename issue
Posted by aliba
January 25, 2014 08:42AM
freerapid 0.9u3
easybytes plugin 2.0.1
I actually don't know if it is a freerapid issue or a easybytes plugin bug.
There is a problem when filename contains unusual chars: [www.easybytez.com]
Downloading doesn't start and freerapid diplays: Error - tag containg 'method_' on the title was not found!
Edited 1 time(s). Last edit at 01/26/2014 10:00AM by aliba.
Re: strange chars on filename issue for easybytes.com
January 26, 2014 04:32AM
Thanks for the report smiling smiley
Fixed in XFileSharing plugin v1.0.14.
January 26, 2014 10:02AM
so it was not a easybytes plugin problem.
I tested also other links with strange chars on filename and now it works fine.
thank you!
