Problem with HOTFILE.COM plugin
May 14, 2009 08:44AM
FRD Version : 0.82
Plugin version: 0.6.3 (hotfile.com by Kajda+Arthur Gunawan)
When the hotfile.com URL contains spaces and parenthesis at the same time, download fails. It generates an error message, which actually contains only the hotfile URL truncated, and no other information.
It appears that the URL is truncated at the position of the parenthesis.
I have uploaded a test file with the conditions mentioned above, which generates the same problem...
[hotfile.com]
Spaces replaced with "_" by hotfile, but the filename still appears with spaces on the download page.
Re: Problem with HOTFILE.COM plugin
May 14, 2009 06:51PM
Fixed, version 0.64.
Thanks for detailed reporting.
Edited 1 time(s). Last edit at 05/14/2009 06:52PM by Vity.
May 14, 2009 07:21PM
Thanks a lot for your immediate response, and for solving the problem! You were remarkably quick! smiling smiley
FRD is amazing, worth of taking the time to vote for it! thumbs up
June 22, 2009 05:41AM
version 0.64 not working now.
June 22, 2009 08:37AM
it seems that hotfile has changed the download page again, i only get a error message with "Tag with containing "Click here to download" was not found!"
Update:
Now there is a captcha on the hotfile download page.
Edited 1 time(s). Last edit at 06/22/2009 08:41AM by NeoFree.
June 22, 2009 12:17PM
I tried some links and it worked fine (no captcha). Can you tell me, when the captcha is required? Can you post a test link?
June 22, 2009 08:39PM
The captcha appears only on downloads for big files. I tested it with a simple text file and there was no captcha but if i try to download a 300 Mb file a captcha appears.
June 22, 2009 10:31PM
"The captcha appears only on downloads for big files.."
That doesn't seem to be the case anymore.
I just encountered this fenomen on a file that was less than 2Mb, so it looks like they might be in the process of changing it to be captchas on all files,
or maby 2Mb is considered a large file @ hotfile.com....
June 23, 2009 08:13AM
Same problems here, the damn capcha
June 23, 2009 08:37AM
The new version of the plugin works fine!
