Flickr plug-in not work for https (clipboard monitoring)
April 06, 2014 05:41PM
plugin-version flickr.com 1.1.1
Flickr redirected all my http connections to https recently.(I had tried the IE8 and Chrome.)
And it seemed that the FreeRapid can't recognize the flickr https hyperlink from the clipboard data.
(I used to download the flickr images by select the image thumbnails in the browser and press Ctrl+C, then the FreeRapid would get all the http image hyperlinks for download.)
Re: Flickr plug-in not work for https (clipboard monitoring)
April 09, 2014 09:55PM
Flickr plugin v1.1.2 now supports https.
April 10, 2014 06:35AM
It works well now.
By the way, is it possible to limit the size of the filename.(ex. truncate to 200 chars)
Some photos can't be downloaded because of the filename length.
The "Flickr plugin" (or FreeRapid) will rename a unicode char to six chars. And the Windows imposes a 260 maximum length for the Path+Filename.
Regars,
Simon
April 10, 2014 12:52PM
@simon886
Please provide sample link.
April 10, 2014 05:15PM
It rarely happened.
I had PM you the sample links.
Simon
April 10, 2014 10:11PM
The unicode issue fixed in plugin v1.1.3.
April 11, 2014 11:23AM
I love the v1.1.3 filename rule. The unicode filename is much meaningful than the six encode chars.
