VEEHD problem
Posted by artwest
VEEHD problem
August 15, 2014 02:07PM
I've had a problem over the last few days downloading new videos on VEEHD
I get the error message : No string between 'url"."' and "" was found
Problem links examples:
[veehd.com]
[veehd.com]
It isn't just these - as a test I just tried the ten most recent uploads and they all failed.
My FRD version is 0.9u4 build #635 - VeeHD plugin version 1.0.0 -
I tried updating FRD and plugins but there were no new versions.
Thanks for a great piece of software.
Regards
Artwest
Re: VEEHD problem
August 15, 2014 03:56PM
Can you watch the videos via browser? I can't, it insists me to download Veehd plugin, that of course I'm not willing to do that.
Re: VEEHD problem
August 15, 2014 04:40PM
Hi
Thanks for the response. I'm the same I'm afraid so I can't tell you.
Maybe there is someone here who has downloaded the VeeHD plugin and can kindly tell us?
Anyone?
Regards
Artwest
Re: VEEHD problem
August 15, 2014 05:05PM
If it helps at all, I've come across one older link which, for some reason, still does work while most old ones now don't:
[veehd.com]
I don't know if this might tell you anything,
Regards
Artwest
Re: VEEHD problem
August 17, 2014 04:56AM
Hmm.. I'm not sure what is happening. I can download your last sample, but can't watch it in browser. I tested your sample #1 several times, the plugin once successfully downloaded the video, but just that one occasion, weird.
IIRC it happened before, some videos from Veehd couldn't be downloaded, but successfully downloaded few days later.
I'm afraid there is nothing we can do right now, because the videos are not working in browser, so we can't analyze it properly.
