Filejoker problem
Posted by Sampiero77
Re: Filejoker problem
November 01, 2015 06:21AM
free-anonymous and free-registered users both are required to enter a captcha, only premium users avoid the captcha
if the captcha type used worked in FRD the wait time would reduce from 120 seconds to 90 seconds for registered users
see filejoker site to confirm details (table below payment options)
November 04, 2015 03:05AM
OK, in that case I'm recieving through your plugin strange captcha. On Filejoker website it is mostly "number", but through FRD it is always some two words. Hardly to read and never accepted.
Are you experiencing the same, or somebody else?
Max
November 04, 2015 10:58PM
DMax wrote:
> ... I'm recieving through your plugin strange captcha.
> Hard to read and never accepted.
Please read
How to make ReCaptcha readable
as a possible interim solution; worked for me!
Regards
Edited 1 time(s). Last edit at 11/08/2015 04:22PM by TVjunkie.
November 05, 2015 09:06AM
Thanks TVjunkie. It appears that without any update the captcha has changed and is working now (is readable)
