another weirdness for bbc.co.uk
Posted by ilanad
Re: another weirdness for bbc.co.uk
May 19, 2015 11:46AM
Works fine for me with VPN, for example : [www.bbc.co.uk].
Can you provide example link that doesn't work?
Edited 1 time(s). Last edit at 05/19/2015 11:47AM by tong2shot.
May 19, 2015 12:16PM
Link [www.bbc.co.uk] working via proxy (example, "fresh" proxy from list [free-proxy-list.net] 81.137.100.158 8080 anonymous)
Link [www.bbc.co.uk] and [www.bbc.co.uk] download 0 bytes.
High speed free VPN [freecloudvpn.com] (i use this) not working at this time. Other VPN run very slowly - I do not use.
Edited 1 time(s). Last edit at 05/19/2015 12:21PM by rancor.
May 19, 2015 12:26PM
Just tested your example links : [www.bbc.co.uk] and [www.bbc.co.uk]. Both samples work just fine.
So it's proxy problem.
Here is my plugin settings : SettingsConfig{videoQuality=480p, rtmpPort=1935 (default), cdn=Limelight}.
May 19, 2015 09:58PM
I use a variety of proxy and the problem only occurs when downloading files with max. 480p (old series without HD versions), HD (720p) downloading OK. Change the settings to other resolutions - downloading 0 bytes.
File [www.bbc.co.uk] downloading in 720p OK, with settings 480p in plugin: 0 bytes.
This is not a problem with the proxy.
May 19, 2015 10:54PM
I can download the example just fine, either 480p or 720p, with limelight as CDN.
Please post your plugin settings, screenshot would be better.
May 20, 2015 12:18AM
Download example file [www.bbc.co.uk] with Limelight CDN, hightest available quality, port 1935 via proxy 80.253.111.240 8080 (or other proxy, transparent, anonymous, elite) Download in 720p OK, other resolutions 0 bytes.
These files only in max 480p and download 0 bytes with various settings CDN (with Akamai) and quality (without hightest available) [www.bbc.co.uk] [www.bbc.co.uk] [www.bbc.co.uk] [www.bbc.co.uk]
VPN [freecloudvpn.com] still does not work, I'll try tomorrow if we start working.
Edited 1 time(s). Last edit at 05/20/2015 12:22AM by rancor.
May 20, 2015 12:56AM
rancor is right: Unfortunately, this is NOT
a wrong proxy issue; instead it is a more ominous
change implemented by the BBC sometime
over the last weekend, or most probably since
Mon May 18th 2015!
If this is a permanent change, it would mean that
by using the Tor plugin/http UK proxy/"smart DNS"
service, only the HD (720p) TV files are accessible
from overseas (i.e. non-UK IPs) by FRD or other
BBC iPlayer downloaders
...sad smiley
ANALYSIS (for the devs and others who need
to get to the bottom of this):
Let me again bring you a quick summary from
some of my previous posts:
There are 3 different CDNs that serve BBC TV
content over RTMP protocol:
1. Akamai (Ak), hostname: "cp41752.edgefcs.net"
This serves all available quality variants (resolutions),
224p, 360p (@480kbps), 360p (@800kbps), 468p, 720p.
This has always been geo-blocked at FMS level,
meaning the server would reject connection from
overseas if Tor plugin/http UK proxy/"smart DNS"
is used...Successful connection & download achieved
via UK VPN (PPTP, OpenVPN and others), Socks4 proxy,
SSH tunnel to a UK server and the likes...
2. Limelight (Ll), hostname: "bbcmedia.fcod.llnwd.net"
This serves all SD resolutions, i.e.
224p, 360p (@480kbps), 360p (@800kbps), 468p.
This has been always non-blocked at FMS level,
meaning Tor plugin/http UK proxy/"smart DNS", when
used with FRD, could successfully start a fetch...
3. Level 3 (L3), hostname: "iplayertokfs.fplive.net"
This serves only HD resolution, 720p. Has always been
non-blocked at FMS level, so the same usage
comments I made for Ll apply for this one, too.
NB: From late Jan 2015 to mid-March 2015, this CDN
was partially broken, often for both UK and overseas,
but usually for non-UK IPs - this has been now fixed.
The last time I downloaded something from Ll was
on Sat 16/05/2015, ca. 15:00 UTC (pid=b05vs0x4).
Sometime since then, the BBC have implemented
geo-blocking to Limelight CDN, too
Further research on my part has shown that the
hostname has changed to: "bbcfmt.fcod.llnwd.net",
which is UK-only!
With both Ak & Ll blocked at server level, no SD
download is possible anymore with just "proxy" usage...
The issue had been reported earlier today (19/05)
in the get_iplayer support forum at the following URL:
https://squarepenguin.co.uk/forums/topic/tvmodes-flashvhigh-flashhigh-flashstd-not-working/
but since they do not tolerate discussion
about overseas access, the thread was initially
hastily closed, and later completely deleted!
More info can be found at the GetiPlayerAutomator
issue tracker (this is a MacOS frontend for get_iplayer),
where "overseas access" is better tolerated,
since the original author of the app is an American:
get-iplayer-automator/issues
(and the following comment by "mostlyotter").
I have conducted my own tests and all
agree with mostlyotter's findings:
If I use a (verified to work) UK http proxy in Firefox,
sample programme pid=b05wdnst DOES NOT PLAY
in SD from Ll CDN (nor it does, of course, from Ak);
see attached screenshot.
If I connect through a UK VPN, then the same show
DOES STREAM OK from the Ll CDN, see 2nd screenshot...
To establish this further, I used the mediaselectorURL
to gather the necessary data to compile an rtmpdump
download command for Limelight:
pid=b05wdnst => vpid=b05wdnqk
Then, from a UK IP (proxy):
RTMPstreams-data
=> rtmpdump command for 468p (token lasts about 1hr):
rtmpdump -r "rtmp://bbcfmt.fcod.llnwd.net:443/a8984/e3" -a "a8984/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/1500kbps/modav/p02qwwtc_b05wdnqk_1431888493764.mp4,iplayerstream/secure_auth/480kbps/modav/p02qwwtc_b05wdnqk_1431888495161.mp4,iplayerstream/secure_auth/800kbps/modav/p02qwwtc_b05wdnqk_1431888493280.mp4&et=1432087491&fmta-token=03820e4e2b1cb1084f83ece19547f88a23aa1af6bd35c5ec1c27f47970c7f7df" -f "WIN 17,0,0,188" -W "http://emp.bbci.co.uk/emp/SMPf/1.11.13/StandardMediaPlayerChromelessFlash.swf" -p "http://www.bbc.co.uk" -C O:1 -C O:0 -y "mp4:iplayerstream/secure_auth/1500kbps/modav/p02qwwtc_b05wdnqk_1431888493764.mp4" -o "b05wdnqk_1431888493764.flv"
The above command (with valid token) DOES NOT WORK from a non-UK IP:
RTMPDump v2.4 GIT-2014-03-02 (Compiled by KSV)
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
Connecting ...
INFO: Connected...
ERROR: Closing connection: NetStream.Failed
however it DOES WORK when a UK VPN is used:
Connecting ...
INFO: Connected...
Starting download at: 0.000 kB
INFO: Metadata:
INFO:   duration                1699.84
INFO:   moovPosition            36.00
INFO:   width                   832.00
INFO:   height                  468.00
INFO:   videocodecid            avc1
INFO:   audiocodecid            mp4a
INFO:   avcprofile              77.00
INFO:   avclevel                31.00
INFO:   aacaot                  2.00
INFO:   videoframerate          25.00
INFO:   audiosamplerate         48000.00
INFO:   audiochannels           2.00
INFO: trackinfo:
INFO:   length                  42496000.00
INFO:   timescale               25000.00
INFO:   language                und
INFO: sampledescription:
INFO:   sampletype              avc1
INFO:   length                  81592320.00
INFO:   timescale               48000.00
INFO:   language                und
INFO:   sampletype              mp4a
1408.545 kB / 7.36 sec (0.4%)
So, it is a fait accompli: by changing the Limelight
hostname to a geo-blocked one, they have
effectively cut-out all non-UK traffic from this CDN too sad smiley
Be sure they will soon patch up that other
loophole, i.e. the L3 CDN....
Later in the year, the beeb may also remove
the RTMP streams altogether, in favour of
AppleHLS (they have done so for live radio),
or AdobeHDS (as they have done for live TV).
The CDNs for those HTTP formats are all
geo-blocked at server level...
PS: I thank the forum moderators for letting me
post this (and previous) analysis here; I genuinely
feel that (through search engines) many people
will find the documentation invaluable!
A sad day really for BBC lovers!
(Gonna mourn privately now...sad smiley sad smiley sad smiley )
open | download - Limelight-UKhttpPROXY.jpg (56.5 KB)
open | download - Limelight-UKVPN.jpg (71.7 KB)
May 20, 2015 01:14AM
@rancor:
Please read my detailed analysis -
the news is NOT GOOD!
Yes, it is unfortunate their UK server is down...
Another good and free VPN I was using
(freevpnnetwork) is also down...
If you find a working VPN, remember it may be
necessary to change the rtmpport to 443 in
the bbc plugin's settings...
I really have no money to spare, but maybe
a paid for UK VPN is a solution - not a good
one, since it would be easy from now on for the
BBC to blacklist VPN IPs (as a lot of traffic
would appear to be coming from a single IP
or a limited range of IPs...)
Commiserations
May 20, 2015 01:54AM
well that explains why I'm getting "ERROR - Cannot download from service' for everything :( someone recommend a trustryworthy UK VPN? I need my weekly Jools Holland fix :(
May 20, 2015 09:34AM
A few hours ago I tried [www.bestukvpn.com] and downloading 480p files OK :) but very slow and unstable, Port 80 , Akamai.
