another weirdness for bbc.co.uk
April 03, 2015 05:05AM
after behaving itself nicely (at SD resolution) for some weeks now, this popped up...
ERROR- Error fetching media selector: 'selectionunavailable'
so far just this one link.....
[www.bbc.co.uk]
Re: another weirdness for bbc.co.uk
April 04, 2015 02:10AM
FWIW, sometime in mid-March the Level3 HD CDN
got fixed smiling smiley ; this is the CDN that works with UK HTTP proxy
or the Tor plugin (with known... problems, as far as the
latter is concerned...grinning smiley).
Try a show available in HD by selecting "720p", "Level 3"
& "Enable Tor" in the latest (v1.2.8) BBC plugin -
it should now download in HD... winking smiley
> [www.bbc.co.uk]
It's an error on their end - I can't get past the ident (BBC One) clip
in a browser by using either a UK http proxy or a UK VPN...
Nothing you can do...
@tong2shot:
for pid=b05pl7rt
http://www.bbc.co.uk/programmes/b05pl7rt/playlist.json
produces two versions:
"Original", with duration 2100s=35min & vpid=b05pvl0w and
"Shortened", with duration 1800s=30min & vpid=b05pl7rr
The "Original" is the one posted on iPlayer (Duration 35 mins)
but it doesn't play (nor can it be downloaded by FRD), because
http://open.live.bbc.co.uk/mediaselector/5/select/version/2.0/mediaset/pc/vpid/b05pvl0w
(from a UK IP) yields:
Language: XML
-<mediaSelection> <error id="selectionunavailable"/> </mediaSelection>
However,
http://open.live.bbc.co.uk/mediaselector/5/select/version/2.0/mediaset/pc/vpid/b05pl7rr
(from a UK IP) DOES PRODUCE stream data, so it is downloadable;
for the Limelight CDN - not geo-blocked - and 1500 bitrate, I compiled this rtmpdump command (token is good for only an hour) :
rtmpdump -r "rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3" -a "a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/modav/bUnknown-7d61f6ca-9f47-4940-831b-1b866aa2c6c4_b05pl7rr_1427930081941.mp4,iplayerstream/secure_auth/1500kbps/modav/bUnknown-7d61f6ca-9f47-4940-831b-1b866aa2c6c4_b05pl7rr_1427930079813.mp4,iplayerstream/secure_auth/800kbps/modav/bUnknown-7d61f6ca-9f47-4940-831b-1b866aa2c6c4_b05pl7rr_1427930077180.mp4,iplayerstream/secure_auth/480kbps/modav/bUnknown-7d61f6ca-9f47-4940-831b-1b866aa2c6c4_b05pl7rr_1427930082837.mp4&et=1428116245&fmta-token=a93941c919b5d7e1f0b3a339fc1ef52331eca141c172821bf6ab37e968349bb8" -f "WIN 17,0,0,132" -W "http://emp.bbci.co.uk/emp/SMPf/1.11.9/StandardMediaPlayerChromelessFlash.swf" -p "http://www.bbc.co.uk" -C O:1 -C O:0 -y "mp4:iplayerstream/secure_auth/1500kbps/modav/bUnknown-7d61f6ca-9f47-4940-831b-1b866aa2c6c4_b05pl7rr_1427930079813.mp4" -o "b05pl7rr_1427930079813.flv" -e
which quickly fetches a 324 MB flv file.
The bbc plugin could be perhaps patched so as to try all available vPIDs for a given PID until it finds stream data;
this is a bug that has been fixed in get_iplayer in the past, so ilanad's sample downloads fine with:
perl get_iplayer-292.pl --pid=b05pl7rt --modes=flashvhigh --force --raw
Best regards (and Happy Easter)
April 06, 2015 01:34PM
The sample link is working fine now. So I guess it was temporary problem. The requested feature (to try all available vPIDs for a given PID) has just been implemented in plugin v1.3.0, anyway.
April 07, 2015 09:31PM
> So I guess it was a temporary problem.
Yes, the issue was reported to the BBC:
Latest programme issues
and they fixed it...
As ever, many thanks tong2shot smileys with beer
jm
April 12, 2015 01:10AM
Not sure whats up. the last few days 9 times out of 10 FRD only wants to get the lowest quality stream from iplayer, no matter setting I have the plugin on. I'm using VPN. Have had to resort to other means
April 12, 2015 01:42PM
Could you provide sample links ?
I'm also using VPN, works fine for me with this link : [www.bbc.co.uk].
My config : SettingsConfig{videoQuality=Highest available, rtmpPort=1935 (default), cdn=Limelight}
Make sure the show available in HD.
jm
April 16, 2015 07:08PM
I dont always want to get all shows in HD, sometimes I just want the 1500k 832x468 file. It is random. Just now using VPN with FRD set to 480p 1935 and Akamai, files for Masterchef UK ep17 and 19 worked fine, but ep 18 would only get the 640x360 796k file. I had to use another program to get the 1500k file.
bbc.co.uk
April 17, 2015 12:51PM
I can reproduce that now. The sample link has two vpid : p02p3j3y, b05rp3f9. The default is p02p3j3y, so plugin picked it. But they only provide 360p videos for vpid p02p3j3y. Vpid b05rp3f9 contains all possible video qualities.
Please try plugin v1.3.1.
jm
April 18, 2015 01:23PM
Thanks for the update. Appreciate your help
May 19, 2015 06:56AM
Another problems with BBC. Download 0 bytes (or "cannnot download from service") via proxy (any type) and any type CDN. Via VPN error "cannnot download from service".
Edited 1 time(s). Last edit at 05/19/2015 06:56AM by rancor.
