Sendspace.com Problem
August 09, 2015 05:04PM
Sir,
For Sendspace.com link, "Received Fatal Handshake Failure" message got.
Any remedy please.
Sample: [www.sendspace.com]
Re: Sendspace.com Problem
August 10, 2015 11:06PM
See here: [wordrider.net]
August 12, 2015 09:17PM
thumbs up sample link provided smileys with beer
I received ERROR
Language: HTML
Tag <A> containing 'start download' was not found!
this error resolved in latest plugin smiling smiley
Edited 1 time(s). Last edit at 08/12/2015 09:18PM by birchie.
August 16, 2015 02:19PM
In [wordrider.net]
ntoskrnl Wrote:
> Okay, it seems like SendSpace only supports
> AES-256 based cipher suites. Java does not allow
> those by default.
> There is a workaround for this. It's implemented
> in the Tor plugin, and should probably be added to
> the main program as well. But you'll have to wait
> for the next version at minimum.
> The "correct" solution is to install the unlimited
> cryptography strength policy files. It can be a
> bit tricky, but you can download them here:
> [www.oracle.com]
> loads/jce8-download-2133166.html Extract the two
> .jar files into your Java installation folder\lib\security.
Extracted the two .jar files as told.
It worked. Thanks much.
