Problem with non-Premium Turbobit.net and Hitfile.net
Posted by IB_HRO
August 14, 2015 04:41PM
In normal (non-Premium) downloading from Turbobit.net, as well as with Hitfile.net (by the way, the design of a page downloading and processing algorithm had exactly the same, but the cause of the malfunction is not the point - under the new design files were downloaded successfully) files ceased to be downloaded: issued a message "File ID not found". The difference between sharing services at the same time the one that counted Turbobit.net first 4 seconds and then a message is issued, and for Hitfile.net error is issued immediately after copying a string download.
Unfortunately, I can not imagine a log-file: when he was forced to move from Windows XP to Windows 7, had a couple of pretty long not ready files on these file storage, hard disks from the old computer was connected to the new, both external and the program FreeRapid Downloader 9.4 was moved to one of the internal logical hard drives, so this file will be a problem. Operating System - Windows 7X64 Ultimate.
Re: Problem with non-Premium Turbobit.net and Hitfile.net
August 16, 2015 10:48PM
thumbs down no sample links or log file provided sad smiley sad smiley
Turbobit and Hitfile had different errors
both plugins fixed smiling smiley
August 17, 2015 06:32AM
You are right and wrong at the same time. Right in saying that the error filehosting Hitfile.net was another, namely "File name not found". You, by the way, you have already removed. A wrong is that now both services offer one and the same error - "File ID not found".
Links: [hitfile.net] and [dl.rapidlinks.org] (Turbobit.net)
Edited 1 time(s). Last edit at 08/17/2015 06:36AM by IB_HRO.
August 17, 2015 09:30PM
Turbobit and Hitfile fixed now
August 18, 2015 09:30AM
Problem solved! Thank You!!! smiling smileythumbs up
