How to make ReCaptcha readable (for Nitroflare, DataFile, etc)
Posted by tong2shot
Re: How to make ReCaptcha readable (for Nitroflare, DataFile, etc)
March 16, 2016 04:53PM
Hi Tong2shot,
Thank you for your help and guide line. It working now with the recaptcha (slimerjs). I am still don't know where to get the recaptcha 1.2. My donation is sending to you in next few days.
Best regards
nb1001
March 16, 2016 06:13PM
Recaptcha plugin is a normal plugin like others. Check your plugin list in FRD
March 17, 2016 05:48AM
Now I found a problem with datafile.com.
The recaptcha put the number right, but doesn´t "detect" the waiting time to starting download (usually 30 to 45 seconds).
So, it´s always asking the numbers and never start downloading.
March 18, 2016 09:40PM
the datafile plugn is working for me
datafile.com may be running slow, there was no sign of the 30sec wait but it still took over 2min before the download started confused smiley
March 22, 2016 10:35PM
number1001 Wrote:
> Hi tong2shot
> where can I download the recaptcha 1.2 as you
> mentioned ?
> Thank you
Help -> Check for new plugins.
April 29, 2016 03:01PM
my FreeRapid not have installed the plugin and update recaptcha and do not download, I can do to install it, Greetings
May 17, 2016 04:06PM
hello, use freerapid 0.9u4 and preference-plugins-configuration not recaptcha plugin appears to me even though I have updated plugins and when I get the window to use the tool slimrjs is blank, thanks
Edited 1 time(s). Last edit at 05/17/2016 04:07PM by tareco.
May 19, 2016 10:33AM
@tareco: can you do some test for me, as mentioned in this post?
August 01, 2016 12:50PM
I've tried to search but couldn't find anything. Not on a Windows PC. I'm on a Mac. Is there a solution for Mac users?
August 01, 2016 01:50PM
@tomm_jones: [wordrider.net]
