[Solved] - Problems
Posted by AmosDE
[Solved] - Problems
May 17, 2016 06:28AM
Hello,
i use FRD since a few weeks without a problem...
At the moment i have one...the problem is the program want start...
When i start it nothing happens...I did update java and still nothing...
I can see the program inside the task manager but thats all...any help?
Thanks smiling smiley
Edited 1 time(s). Last edit at 05/18/2016 10:31AM by AmosDE.
Re: Problems
May 17, 2016 02:34PM
Please attach your app.log file which is situated in c:\Users\Vity\%USER%\Roaming\VitySoft\FRD\log\ directory.
Re: Problems
May 18, 2016 07:32AM
Here u go but not much info inside...
Sat May 14 23:54:40 CEST 2016 WARNING: Couldn't create fir C:\Users\user\AppData\Roaming\VitySoft\FRD
open | download - app.log (515 bytes)
Re: Problems
May 18, 2016 07:36AM
Then try to delete that C:\Users\user\AppData\Roaming\VitySoft\FRD folder. BEFORE that
1. backup these files:
frd.odb
frd.xml
links.txt
2. Run FRD
3. Update plugins
4. Close FRD.
5. Overwrite new files with backup files
Re: Problems
May 18, 2016 09:58AM
Ok after i have done what u said it started again and and try to download the new plugins...
Now this:
Seems like a problem with the internet access, so i disable avast but still the same problem...
Re: Problems
May 18, 2016 10:06AM
Please attach your app.log file again. There should be more info.
That's weird, but try to do following:
1. Close FRD.
2. Open startup.properties file with some text editor (eg. notepad) , which is situated in FRD home folder
3. Add this line into that file
-Djava.net.preferIPv4Stack=true
4. Run FRD again
Re: Problems
May 18, 2016 10:09AM
Ok i did find the problem myself:
-[stackoverflow.com]
A fews days ago a ad-ware called "RelevantKnowledge" was installed on my pc...i dont no where it came from and
i did forgot to remove it...
Now i removed and override the files and anything works fine again...
Its really weird because i dont know where RelevantKnowledge came from...
Anyway thx for your help...i will donate when i am not totally broke anymore cool smiley
Greetz from berlin
Re: Problems
May 18, 2016 10:11AM
P.S. Sadly here is no thank you button :(
Re: Problems
May 18, 2016 10:12AM
nicht zu danken.
Re: Problems
May 18, 2016 10:14AM
Hehe du surfboard nerd sprichst ja deutsch...eure software ist sehr knorke...ich benutze eigentlich seit Jahren @#$%& aber wegen der captchers werd ich wohl umsteigen...
