Slimerjs not working anymore for me
February 21, 2017 08:50PM
Hope it's fixable, I think firefox may have updated but nothing else changed on my computer, I don't believe.
FRD says ERROR - java lang IllegalStateException No SlimerJS capture response.
It was working just a little while ago, I don't know what happened.
Hope you can help. Thank you.
Almost forgot, here is a link [turbobit.net]
Edited 1 time(s). Last edit at 02/21/2017 08:51PM by AnitaN.
open | download - Capture.JPG (25 KB)
Re: Slimerjs not working anymore for me
February 22, 2017 08:56AM
I have the same problem here...
confused smiley
March 14, 2017 09:41AM
use standalone version, lightweight won't work anymore
oh... new slimerjs version came out
Edited 1 time(s). Last edit at 03/14/2017 09:45AM by tekko.
March 15, 2017 03:36PM
Thank you so much tekko. smiling smiley
The new version worked, lightweight worked great!!!
thumbs up smiley
April 07, 2017 12:26PM
Thanks for the report, the "How to" instruction has just been updated.
In the future, if you're using the lightweight version and something goes wrong, make sure you're using the one that compatible with your Firefox browser, usually it's the latest one (choose slimerjs-x.yy.z.zip file, for example: slimerjs-0.10.3.zip). To check SlimerJS compatibility, open "application.ini" file in your SlimerJS installation folder, it's in "Gecko" section (MinVersion, MaxVersion).
This is why we recommend the standalone version.
