depositfiles is not working for me
March 24, 2017 07:59AM
Since a couple of days depositfile doesn't seem to work for me.
The validatiing works.
I get the captcha but after I put in the captcha is the the progess message "Error - Starting download"
I've tried in on a Windows and MacBook on different networks but is still gives the same.
I tried is with this: depositfiles.com/files/fgki4bkl9
It gives a reponse when i tried in i the browser.
I've run the application the the -d flag and the output is attached.
open | download - ouput.txt (2.3 KB)
Re: depositfiles is not working for me
March 24, 2017 08:03AM
Same for me.
March 24, 2017 06:27PM
Same for me,
any solution plz ?
March 27, 2017 12:09AM
thumbs up sample link provided smileys with beer
depositfiles plugin fixed smiling smiley
March 27, 2017 05:37PM
Many thanks birchie cool smiley
April 17, 2017 12:12PM
I'm getting this error:
ERROR - Remote host closed connection during handshake
Any luck with this one?
April 17, 2017 05:53PM
... Possibly related to this recent thread; are you on a Mac, too?
@birchie
Can you kindly offer some more concrete advice
to those experiencing that SSL error, especially on a Mac?
FWIW, no such errors here
(Windows Vista SP2 x86 with latest (and last! sad smiley ) system updates,
JRE 8u121, FRD 0.9u4, depositfiles.com plugin v1.4.15, SlimerJS 0.10.2).
April 17, 2017 07:39PM
It appears to be the same error and issue. I'm on an older Mac (10.9.5) and was using no installed Java. First thing I did was install Java but it still doesn't work. I'll keep an eye out for the other thread to be updated.
April 17, 2017 08:08PM
... Have you tried the following workaround ?
>> It seems that the DMG version still insists on using the old Java 6 supplied by Apple on the operating system,
>> even though Java 7 or 8 has been installed from Oracle.
>> In a last ditch attempt, I completely deleted the FreeRapid-0.9u4.app from the applications folder
>> and downloaded the FreeRapid-0.9u4.zip (All Platforms) version.
>> I have the program running as a "JAR" file now and it is functioning without any problems.
>> I guess there is something weird with the MacOS App version not wanting to work with the latest Java.
Also try installing the unlimited cryptography strength policy files for latest installed JRE8 from Oracle...
Please report back winking smiley
