rapidgator_premium plugin doesn't work
August 16, 2017 01:35AM
I've been using rapidgator_premium plugin for years, and today I have a problem.
It worked fine until yesterday.
Today when I copied the url at rapidgator site, FRD didn't work.
Even I pasted the url to the Insert new URLs window, the following message appeared.
Following URL(s) are not supported by download plugins.
Do you wish to remove them?
[rapidgator.net]
Then I updated the JRE version to 1.8.0_144-b01, expecting it'll fix the problem.
Does this problem have anything to do with the version of JRE?
Please tell me how to solve it.
Windows 10 Home Version 1703 Build 15063.540 (64bit)
JRE 1.8.0_144-b01 (x86)
FRD-0.9u4
rapidgator_premium 1.1.8
I attached the file app.log in debug mode.
Edited 1 time(s). Last edit at 08/16/2017 05:25AM by xxyz0431.
open | download - app.log (5.5 KB)
Re: rapidgator_premium plugin doesn't work
August 16, 2017 03:59PM
Here is workaround:
1. use 7zip to unzip C:\Users\JR\AppData\Roaming\VitySoft\FRD\plugins\rapidgator_premium.frp
2. edit plugin.xml
http://(www\.)?(rapidgator\.net|rg\.to)/(file|folder)/.+"/>
to
https://(www\.)?(rapidgator\.net|rg\.to)/(file|folder)/.+"/>
3. re-zip rapidgator_premium.frp
or replace with the attached file (dear ntoskrnl, I'm sorry without your consent.)
open | download - rapidgator_premium.frp (5.5 KB)
August 17, 2017 01:37AM
Thank you for your comment.
I replaced *.frd file in both ways and restarted FRD, but it didn't work...
August 17, 2017 01:53AM
Hi, you need to change old urls from http:// to https://
August 17, 2017 02:26AM
Yes, I added one char "s" after "http" and saved xml file and re-zipped and replaced, but didn't work.
I manually pasted the url starting with http so FRD tried to download without errors, but failed afterwards.
(Error starting download - maybe due to http protocol)
Do I have to flush the settings of this plugin? I don't know how though.
August 17, 2017 02:42AM
try the new attached file.
open | download - rapidgator_premium.frp (8.2 KB)
August 17, 2017 03:10AM
Yes, it worked!
I have to apologize that I remained the old file in plugin folder as "__rapidgator_premium.frp".
After removing the file it worked.
Thank you so much.
August 17, 2017 05:55AM
FYI: changing to "https?://............" will allow both 'http://' and 'https://' urls
rapidgator_premium plugin officially updated smiling smiley
