rapidgator plugin does not work
February 06, 2018 06:50PM
Error:
Could not generate DH keypair
Re: rapidgator plugin does not work
February 06, 2018 09:08PM
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:186)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshaker.java:593)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Handshaker.java:529)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:943)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1188)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:654)
at com.sun.net.ssl.internal.ssl.AppOutputStream.write(AppOutputStream.java:100)
... 23 more
Caused by: java.security.InvalidAlgorithmParameterException: Prime size must be multiple of 64, and can only range from 512 to 1024 (inclusive)
at com.sun.crypto.provider.DHKeyPairGenerator.initialize(DashoA13*..)
at java.security.KeyPairGenerator$Delegate.initialize(KeyPairGenerator.java:627)
at com.sun.net.ssl.internal.ssl.DHCrypt.(DHCrypt.java:107)
... 31 more
February 09, 2018 11:28PM
anyone?
February 17, 2018 01:11AM
- upgrade to java8 or higher
- try freerapid 1.0 beta
February 18, 2018 12:20AM
works now, dunno what happened, mabye a plugin update?
