slimerjs (ful and litel) problem
Posted by xcoder
May 24, 2018 08:33PM
slimerjs-0.9.6
slimerjs-1.0.0
The html window is too small to show the bottom of the recaptcha select squares page. At first it may look ok but requires entering 10+ times before it accepts. and some of the windows with less blocks are taller which stretches image below bottom covering the button. Also, It's a bit slow.
Note, same problem in both versions.
Edited 4 time(s). Last edit at 05/24/2018 09:27PM by xcoder.
Re: slimerjs (ful and litel) problem
May 26, 2018 04:32PM
How to use SlimerJS ?
May 28, 2018 08:42AM
increased size of html window, now shows all of recaptcha select squares page (at least it does for me)
recaptcha identifies FRD as a robot not a browser (it is a robot), so it forces maximum human verification
-- more clicking than a browser and usually requires multiple pages to verify
@avi38
see here : [wordrider.net]
May 28, 2018 03:18PM
thanks birchie
@avi38 go here follow links. if you use firefox(recommended) get light one from link"here" in second paragraph
lite ver - get the 1.0.0 zip rename extracted folder to slimerjs an put in tool folder. bada bing captcha should work
[download.slimerjs.org]
