Pornhub Problem
June 13, 2018 08:03PM
FRD Version: 1.0 Beta
Plug-in Version: pornhub.com 1.1.5
Download Link: [www.pornhub.com]
Error:
Message:
java.lang.NullPointerException
Level:
SEVERE
Stack Trace:
null
cz.vity.freerapid.plugins.services.pornhub.PornHubFileRunner.deJsVideoQualityUrlsSection(Unknown Source)
cz.vity.freerapid.plugins.services.pornhub.PornHubFileRunner.run(Unknown Source)
cz.vity.freerapid.plugins.webclient.AbstractFileShareService.run(AbstractFileShareService.java:106)
cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:98)
cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:42)
javax.swing.SwingWorker$1.call(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
javax.swing.SwingWorker.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Edited 1 time(s). Last edit at 06/13/2018 09:11PM by spammehere.
Re: Pornhub Problem
June 17, 2018 09:27AM
I can't reproduce this issue. I added some more debugging to plugin v1.1.6, please update and attach the log file after the error again.
Re: Pornhub Problem
June 18, 2018 12:36AM
I updated plugin to 1.1.6
not worked
here is the log:
Mon Jun 18 08:32:08 CST 2018 SEVERE:
cz.vity.freerapid.plugins.exceptions.PluginImplementationException: JS 1 evaluation error null
at cz.vity.freerapid.plugins.services.pornhub.PornHubFileRunner.deJsVideoQualityUrlsSection(Unknown Source)
at cz.vity.freerapid.plugins.services.pornhub.PornHubFileRunner.run(Unknown Source)
at cz.vity.freerapid.plugins.webclient.AbstractFileShareService.run(AbstractFileShareService.java:102)
at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:98)
at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:42)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.lang.NullPointerException
... 11 more
Mon Jun 18 08:32:26 CST 2018 WARNING: Couldn't create fir C:\Users\user\AppData\Roaming\VitySoft\FRD
Re: Pornhub Problem
June 18, 2018 04:03PM
There should be page content in the log file. Could you attach the whole file?
Re: Pornhub Problem
June 18, 2018 04:24PM
Log file
open | download - app.log (306.5 KB)
Re: Pornhub Problem
August 04, 2018 09:32AM
thumbs up sample link provided smileys with beer
unable to replicate error, but change made based on log file
plugin could be fixed smiling smiley
Anyone can create & fix plugins
Re: Pornhub Problem
August 21, 2018 01:47AM
Not Worked
Log file attached
FRD Version: 0.9u4
Plug-in Version: pornhub.com 1.1.7
Download Link:Link
Edited 1 time(s). Last edit at 08/21/2018 07:49AM by spammehere.
open | download - app.log (311.8 KB)
Re: Pornhub Problem
December 14, 2018 03:43AM
still unable to replicate error
plugin hopefully fixed for you this time smiling smiley
Re: Pornhub Problem
December 19, 2018 05:14AM
I think it is pornhub doing some sort of anti-DOS thing or preventing people from queuing up downloads. I have been getting a "ERROR - JS 1 evaluation error ReferenceError: "player_mp4_seek" is not defined in at line number 1" (note that the multiple spaces after "in" and before "at line number 1" is not a typo) and sometimes it just goes "ERROR - File name not found". It only happens if you have a large number of downloads queued up, and the interesting thing is that if you don't download more than 3-5 at a time and manually hit control-w to start the next download it will work. Yet lowering the queue to 1 does NOT work, it will just result in another error.
Giving a link won't help, I'd need to give more than a dozen before the error starts reproducing itself. It also seems to time out after a couple days and the queue will work if you don't start more than ~10 downloads. Try to do more and you start having the issue.
Makes me think it is some kind of anti-DOS or anti mass downloading thing.
At least that is what I'm noticing when I tried to download about 3 dozen short videos of <10mb each.
Edited 1 time(s). Last edit at 12/19/2018 05:15AM by slickrcbd.
Re: Pornhub Problem
December 31, 2018 02:49AM
FRD Version: 0.9u4
Plug-in Version: pornhub.com 1.1.8
It Works
