Uloz.to doesn´t work
November 19, 2018 03:46PM
Hello.
I have the plugin version to uloz.to 1.3.21 and when I want to download some file it says: ERROR - Connection timed out: connect.
I can not download at all. I still have to enter CAPTCHA codes. When I check the plugins, I do not have any plugin that resolves CAPTCHA. Thank you.
FRD version: 0.9u4
Re: Uloz.to doesn´t work
November 19, 2018 07:52PM
Ulož.to has lately problem with connection, not sure if it's FRD or not, but on Firefox i had to wait for about 2 minutes 'till the download popup appears (the one asking me whetever to save the file..)
This usually happens or more obscure/larger files
Sample link
November 20, 2018 02:10PM
I understand. I have a problem downloading 5 Gb files. I'm still throws the same error. Yes, for smaller sizes (eg 1 Gb) the program is functional. Download usually runs. But I have to download 5 Gb and I do not know what to do about it. If there was an error on FreeRapid, could not it be fixed?
November 23, 2018 06:35PM
Ty same problemy mam asi, tak tyden. Male soubory jsou NEKTERE bez problemu.Velke nejdou s chybou ERROR - Connection timed out: connect.
