please help me with the error with FileFactory, sample links:
www.filefactory.com]
(pass: alwaysgrumpycat.com)
It gives error "No string between 'data-href="' and "' was found"
Now we just recently were fixing another issue (name/size not found), but these are password protected links. I've tried unprotected ones, too, like in this folder
and those seem to download fine. So the problem is only with the password protected links.
I hope there is a way to solve this issue, without too much trouble for you, guys. If there was a way for FRD to remember the password for all the links, that would be great, too. Those files are large and it takes more than 18 hours to download one. So I will hope for the chance of FRD dealing with the password by itself,or at least resuming downloads (meaning after FRD is closed, with some links still not fully downloaded, next time it is open it will continue download from the .part file and not from the zero again).
Thank you and I appreciate everything you guys do.
Cheers,
ha_pi_pi
