problem plugin clicknupload.org
August 23, 2019 02:40PM
hello, the clicknupload.org plugin doesn't work anymore, thanks
Re: problem plugin clicknupload.org
August 23, 2019 06:46PM
Facing same problem from couple of days.
Download does not begin even in the other downloader that cannot be named.
I thought it had something to do with my ISP.
Then I opened the link in browser and tried downloading it with IDM.
Initially it runs into error.. but can be downloaded just fine when I try to resume it.
Samples that just worked in IDM but not FRD
[clicknupload.org]
[clicknupload.org]
October 06, 2019 08:04PM
Hello,
clicknupload says "cannot be downloaded from" on Friday 4.10.2019 the download worked, not today
I have FreeRapid-1.0beta.
thanks smiling smiley
October 08, 2019 12:31AM
The site added DDoS protection to try and stop programs like FRD
thumbs up sample links provided smileys with beer
plugin updated smiling smiley
Anyone can create & fix plugins
October 08, 2019 08:44AM
It works, thanks @birchie
Good to see you back.
February 16, 2020 08:02AM
CNU Domain changed to clicknupload.co
Please add
Sample~ [clicknupload.co]
ipb
March 27, 2020 11:28AM
> Please add
> Thanks
+1
Most links are now .co
Please update plugin, thanks
ipb
February 08, 2021 12:02PM
Any news on updating for .co?
It works for me if I change the TLD from .com .co but the auto clipboard monitoring is not working and wont process .co unless I rename the link to that
It is just a rename that is required and not a plugin re-write so should be simple enough
I have tried to update the plugin.xml myself by changing 'urlRegex' and 'services' but it seems it is hard coded in the class file
