fastshare.cz connection problem ?
Posted by filoted
July 06, 2022 03:25PM
same problem with different type connection (on mobile provider/ local wifi/LAN), same problem on windows 10, Kubuntu.
I use default connection with OS.
make sure the link is working in the browser
all link works with browser
your FRD version – MAKE SURE YOU ARE USING THE LATEST FRD VERSION – 0.9u4
version FRD -0.9u4
your plugin version (please see Options > Preferences > Plugins > Settings),
plugin version -fastshare.cz ver.:1.0.10
describe problematic behavior,
unknow error in host site - Connection problem? (došlo k neznámej chybe na strane hostiteľa - Problém so spojením?)
- provide download link you have problem with (not link with some violent or p0rn content),
for example this link :[fastshare.cz]
-we would appreciate if you attached the app.log file (Help > Browse to log file)
log file are attached.
THX for sollution
open | download - app.log (678.2 KB)
