Problem downloading from ifile.it
Posted by goodfish
September 05, 2009 09:43AM
I meet trouble downloading this link [ifile.it]. But in browser, it do work.
I am using FreeRapid 0.83 + ifile.it 0.65. Error is "ERROR - Connection timed out: connect.
Anyone can help?
Re: Problem downloading from ifile.it
September 05, 2009 08:52PM
I am having a similar error. I have FreeRapid 0.82. When I try to download files from ifile.it, under "Est. time", it says "TESTING" then "ERROR".
Děkuju mockrát za pomoc!
September 08, 2009 04:54AM
Anonymous User
June 30, 2010 07:21PM
Since 30/06/2010 the program does not work with my premium account. In the program there is an error username or password. What could be the reason please help.
July 02, 2010 12:43PM
Fixed.
September 06, 2011 07:18PM
It doesn't work again : "Bad login or password"... =/
September 21, 2011 03:39PM
I'm getting the following error: 'ERROR - File name and size not found'
I'm running the newest version with the newest plugin: FRD 0.85u1 build #566 and ifile.it v0.7.16
Here's a download link (I am able to manually download the file): [ifile.it]
September 23, 2011 10:44PM
Hi, the error has not gone away. I believe I have provided all the necessary information to draw attention to this error. Please let me know if there is anything else I should do. Thank you.
September 29, 2011 03:58AM
Hi, just bumping this.
October 04, 2011 06:38AM
Hello, I will be working on this, and hopefully have this fixed in the next 24 hours, I'll post here when its done!
