ifile.it plugin doesn't work
Posted by bimzcy
December 06, 2009 10:35AM
I remebered that I updated the ifile.it plugin yesterday. Before I updated it, it worked well, however after I had updated it to 0.75 version, the worst thing came, which is, I couldn't download any file from ifile.it any more. Whenever I try to download, the FRD just show the error "No string between 'id="req_btn2" target="_blank" herf="'and'" was found".
So what's that? How could I solve this problem?
My FRD version is 0.83u1 build #522, and here is example links (No matter what link it is, the error is the same):
http://ifile.it/7njz4b5/Official%20IELTS%20Practice%20Material%20-%20Updated%20March%202009.rar
http://ifile.it/p7ijq2s/the_new_prepare_for_ielts.pdf
Thank you in advance, and expecting your answer.
Edited 2 time(s). Last edit at 12/06/2009 10:37AM by bimzcy.
Re: ifile.it plugin doesn't work
December 06, 2009 10:40AM
Both links work absolutely fine for me, and I'm using v0.7.5 too.
December 06, 2009 11:43AM
I found something new: Using the 0.75 version ifile.it plugin to download file directly by FRD, 100% to get error (like what I mentioned above). But if I set up a VPN connection by software such as HotSpot Shield, and then use FRD, it does work!
ifile.it seems not be banned by my SP because I can visit and download file from it directly (I mean don't use FRD and VPN, just visit and download by broswer), and what's more, I can download file by FRD with a former version of ifile.it plugin (maybe it's 0.73, I forgot).
I really don't know the meaning of the error and how it happened, maybe I have to wait until a new update comes.
Edited 3 time(s). Last edit at 12/06/2009 11:50AM by bimzcy.
