PROBLEM WITH UPLOADING.COM PLUGIN
Posted by AnonRJ
December 07, 2009 01:11PM
FRD version = 0.83
your plugin version = 1.5.0
describe problematic behaviour = No string between 'file_id:' and ', action:' was found.
provide download links you have problem with = [uploading.com]
open | download - app.log (55 KB)
Re: PROBLEM WITH UPLOADING.COM PLUGIN
December 07, 2009 01:33PM
Newest plugin version is v1.5.4. Update your plugins.
Also make sure you're using FRD v0.83u1.
December 14, 2009 02:58PM
v1.5.4
the plugin is downloading only a tiny html file but not the wanted file :
random test link :
[uploading.com]
February 02, 2010 07:33PM
> plugins.
How do i update to 1.5.4?
When i check for updates it says no new updates, and i got 1.5.0
Edited 1 time(s). Last edit at 02/02/2010 07:35PM by zappe.
February 02, 2010 07:36PM
> and i got 1.5.0
Make sure you are using FreeRapid v0.83u1.
February 02, 2010 08:58PM
> updates,
> > and i got 1.5.0
I am, build 522.
